Replacing Coolant Overflow tank...(searched)
I'm replacing the bulged/cracked coolant overflow tank on my '86 944 with a new(er) one from eBay... According to the Haynes manual I basically just lower the coolant level, unbolt the tank, and disconnect the hoses....and then do the reverse to install the new one.
Are there any "gotchas" I should keep an eye out for or is it pretty straightforward?
Thanks!
Jeff
Thanks!
Jeff
It's straight forward. My car is a turbo, but it is basically the same procedure. There are different ways to lower your coolant level. I completely drained mine due to other work I was doing. You could take it as an opportunity to drain and flush your coolant system before winter. You just have to deal with bleeding it when you refill. If you don't want to drain it, I would buy a cheap hand pump or just a hose and siphon it out of the reservoir. If you do follow Clark's procedure and drain from the bottom, I would just pull the lower radiator hose near the PS pump from the radiator to drain. There is no way I would mess with the radiator drain plug and risk breaking it when you can pull the hose and it does the same thing. Hope that helps.
Originally Posted by Bob Ward
I'd love to find an aluminmum one to replace the plastic piece!
http://www.lindseyracing.com/Merchan...OLINGSYSBILLET
Is it that hard to look at a vendor page? About $75.
I 'think' the only difference between the 951 tank and the regular 944 tank is provision for the turbo waterpump.
Edit - I just looked at Lindsays page, i am pretty sure if you order the 'dry turbo' one it will work without modification on a n/a car.
