the stupidity...
10-17-2006, 02:50 AM
AddictRennlist Lifetime Member
the stupidity...
10-17-2006, 03:01 AM
The ImpalerRennlist Member
i think im going to get one for my lawnmower
10-17-2006, 03:15 AM
Haha. Almost as good as the "electric supercharger"/vacuum motor that gets you 2psi.
Sounds like a good investment.
You can turbo your NA now! Well, at least sound wise.
10-17-2006, 03:17 AM
How does it work? it looks like it puts your exhaust through a straw!
10-17-2006, 03:19 AM
My guess is that its like a bov for your exhaust?
10-17-2006, 03:58 AM
but it says it goes IN your exhaust, So how does it make that sound?
10-17-2006, 04:01 AM
oh i think i get it, apperantly, the higher exhuast pressures keep the valve closed, then when you let off the valve opens and the gasses going through it, must make a whistline sound just as the valve opens, so Id think youd loose HP as its a restriction
Yeah, would it just plug up the exhaust until enough pressure builds to cause it to make the blow off noice?
10-17-2006, 07:15 AM
10-17-2006, 09:07 AM
10-17-2006, 09:39 AM
Resistance is FutileLifetime Rennlist Member
Screw that... I'm putting that SHI!! on my Explorer.
10-17-2006, 10:41 AM
LOL... I wonder if they make one that whistles more like a VW bug.
Could then turn your turbo porsche into a bug sounding sleeper?
10-17-2006, 11:28 AM
if I put on one on my 951, will that make it a twin turbo?
10-17-2006, 11:58 AM
Budding PhotographerRennlist Member
