Any pictures of a Lindsey Racing vacuum kit installed on a N/A?
Set to Full-Auto
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
Title says it - going to install one tonight on my bother's car, would like some kind of guide to look at.
If your talking about just the silicon vacuum lines i have it done on mine. Not much i can say to help you out about it. I just carefully looked over everything in the engine bay for the black plastic lines, pulled them off.. and cut the new silicon ones to length. The hardest ones to get to are on the backside of the engine, i think one or two connect back here.
Hi Doug,
Nice pics.. If I ever decide to do that I know how to do it now by simply pulling one at a time like you guys have said.
Jim
Jim
Originally Posted by Chums944
Do it just like Shiners780 said. It is very simple. Here are some pictures of mine.
Doug
Doug
Set to Full-Auto
Nice engine bay Doug!!!
Thanks guys, just did it - EASY job, if the intake is off. If you use the Lindsey kit on an N/A car you will have one extra T-fitting and a GENEROUS amount of extra line.
whats the benfit of this? besides looking sharp of course.
i just made a how to
https://rennlist.com/forums/diy-924-931-944-951-968/348704-lindsey-racing-vacuum-install-on-n-a-944-a.html
Set to Full-Auto
Features that I like:
Silicon will remain pliable and not crack with exposure to heat and oil
Flexible and easy to route
Colors available
Metal T-fittings won't break when you look at them wrong
Metal T-fittings are at 90 degree angles, makes for keeping things strait and neat easier
And as you mentioned - it looks damned good.
Thumbls-up to Lindsey, first time I have done business with them and it certainly won't be the last. I ordered two kits, great service and promt shipping - and most importantly - GREAT product!!!!
Colors available
I have done not the vacuum line change myself. But I am hoping to do so in the future. I kept this pic from someone's post in the past. I am not sure if it is off an NA or turbo engine, but I hope this will be useful:
Set to Full-Auto
Thanks - I got everthing changed without drama - I need more zip ties to finish it off and then I will post pictures and tips. There really isn't much to it, alot easier/simpler than I had imagined......
