#2 Piston Ring
Hello.
I have been getting the 3 piston I have right now ready to drop into the block.
I was putting the rings on the other day and getting them all lined up.
The bottom and top went in and had a little bit of play in them, which I would describe as normal.
The middle one with the little shelf on it is REALLY tight. I had to make sure I put it on in the correct position because I couldnt spin it around the piston.
Im not even sure if it will go all they way in when I put the ring compressor on it.
Does this sound normal?
-Brett
-Brett
yeah I made sure that I faced the shelf in the correct direction.
And these are the same pistons. Just had them cleaned and had the rods checked for roundness.
I re-cleaned the ring groves with broken rings and they went in much easeir.
I just found that odd because I had the pistons cleaned at the machine shop.
The three pistons I have are in and moving nicely.
You might want to clean the grooves some more with some solvent and a toothbrush until they are perfectly clean. Alot of carbon builds up in there. Measure the gap again and make sure it's within spec before installing.
____________________________________
1986 944 NA - Guards Red - 91k miles - minty
1983 944 NA - Platinum metallic - 3000 mi beginning a new life
1985.1 944 NA - Guards Red - donor car
1984 911 Carrera Coupe - Guards Red (gone, but not forgotten)
"If you're not living on the edge, you're not living"
