Need a picture...battery tray
I am taking my 951 into a body shop this up coming week to address a rusted battery try. What I need to see is the placement of the inner battery hold down bracked. The one against passanger fender is fine, the inner one broke off and he is going to weld it back in place, but we need to see its placement.
Thanks in advance.
Thanks in advance.
It has been a while since my battery has been mounted firmly at this point. I do not see where the inner mount braces the battery from your picture. What holds the battery in place?
Here is a pic for your efforts.
There is a mounting tab with a hole in it that fits down over that bolt that the cables are attached to. The mounting tab clips down over the extended bottom ridge on the battery.
[A brunette this time please....]
Ah. That is perfect. I thought that piece had broken off and not that is was supposed to be removed. Though that would make sense. Thank you a ton....
Per your request. Bribery goes a long way I see.
