Early N/A DME pinout
Found the manuals on my computer but no pinout..just flow diagrams.
I would really love to installl my piggyback and would be happy to do a picture FAQ if someone can find me a pinout for the early DME.... I can't read those flow diagrams at all. Makes my brain hurt
I would email the guru of the early DME - FR Wilk @ PowerPROM@frwilk.com. He'll know that info if he'll answer your email. His site about the DME can be found at http://frwilk.com/944dme/
Alot of his navigation gifs don't show, but you can mouse over. Personally, I switched to an 87 DME/AFM which smoothed the whole thing out, but that is off topic.
Michael
Michael
Wow, small world. Where abouts in ulster county? I'm out of HS so I really don't follow the sports anymore, but up until last year I know Red Hook was doing pretty well. I know Rhinebeck hasn't won a basketball game on us in 35 years... Thanks for the link, completely forgot about that FRwilk
In order to run a late AFS in a early 944 is to swap the AFS and the DME. Both must be used, you cannot just use the AFS alone it must have the matching DME/ECU.
Yes the connections are identical, simple swap. Only issue now on a early 944 is the late has a ISV the early does not so how the DME reads the idle mixture is a mystery. May need an ISV installed but not certain on this.
Dal
Dal
If you need a late ISV you'd also need the late (bigger diameter) ISV hoses. If anyone is doing this upgrade and needs a late ISV I'll gladly trade a late one for your early one..
So if I am getting rid of the stock AFM and am going to a MAF that reads 0-5v , should I get a late DME or my early one which goes to 12v??
Finally... I can't find a DME pinout...just the AFM pinout. Anyone have any other ideas?
Originally Posted by Charlie944
Thanks Dal...I appreciate the info!
Michael, how does your car run at idle...do you have a Idle control motor?
Do the later J-boots for the 944 have a provision hole for these?
TIA
TIA
I know what the J-boot is, but I am not sure about any provisions for an Idle control motor.
Here is a 944 turbo DME pin-out. I am not sure of how similar they are, but I reckon they are close.
I could not find a pin-out diagram for a NA 944 much less an early model. I searched all through my manual pdf CD, but mainly it emphasizes the 85.5 and later models. Hope this helps you
Before you get too far, measure the voltage on pin 3 of the AFM connector (VAF reference voltage). If the voltage is around 5V then you're OK. If the voltage is much greater than 5V, then you need a piggyback that will generate an output up to that voltage. If the voltage is >5V and the piggyback won't generate the proper output voltage, then get a late model 944 DME to use.
