Electircal engineers/Guru's
How would i set up a row of LEDs to Light up One after another? SO that one lights then the next, and so on, till they are all lit up?
Nerd Herder
Originally Posted by Epic2112
You could hook them up in series with capacitors between them.
Kit.. LMAO.
http://www.action-electronics.com/scanner.htm
http://cgi.ebay.com/ws/eBayISAPI.dll...m=330023308111
http://www.knightlight.co.uk/knight-...s-products.asp
If you want to make your own, there's a chip called a 3914, which is an LED meter driver, then you'd have to design a little circuit to ramp the input voltage to it continuously up and down.
Originally Posted by Chris_924s
How's about aan IC555 timer.. faster, easier. What kind of time delay duration do you need between the 1st and second to the last LED?
