Coffee on Carpet....
I got a spill on my carpet with coffee one morning going to work, is there anything that helps get it out? It isn't on the rug (couldn't be that lucky) so removing and power washing is out. The fabric is a light color too, so it really sticks out.
Resistance is Futile
Got a shop vac with wet suction? Wet it down, soap it up, extract, wet it down again with water, extract, wet extract, extract again, put a fan on it... forget about the spill.
Look in your local Yellow Pages under "janitorial supplies." They will have the good commercial grade stuff, unlike what you get at the local big-box stores for homeowners. What you want is a Tannin Remover for fabric and upholstery. Some places only sell in full cases (12 quarts), keep calling around until you find someone that sells individual quarts.
Follow the directions on the label exactly. Coffee stains are one of the easiest stains to remove.
I spilled a whole LARGE Dunkin Donuts Iced Coffee on the passenger side floor carpet in 90 degree weather and it sat in the sun all day. I just took it to a car wash and they shampoooooood it for me. That did the trick.
I second that ,Be careful of ox-cleen. Just get some warm soapy dish detergent in a small bowl and use a small brush and start scrubbing lightly the most unnoticable place, first. Before you use something that may discolor the carpet with chemicals. Rinse often and use a shop vac to extract the water. Nick G. (((( RENNTREFFEN BUMP ))))
Drama Queen
From: Somewhere in WI in my garage, or circum-navigating the globe in a wooden boat.
i had real good luck with Prestone interior cleaner. works good in the house too. my cat knocked over my ashtray and someone walked it into the carpet, used the prestone stuff and ud never know what a mess there was. and yeah the oxi clean is good too but it can fade easily if u use to much..got some oil stains outa my carhart jacket lickidy split, and also faded the hell outa it.
