Tips on removing speedometer needle?
Yeah, for one of those little jobs, pulling the dial, is one of those ' h*ly ****' daunting tasks. Afterwards you'd want to invent some kind of two prong lifting tools.
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
Go to the link below and it will show how to replace the gear.
http://www.klaindustries.net/gearinstr/gear-instr.htm
Cheers,
Larry
Cheers,
Larry
When you use the fingers method and it is really on there tight, if one finger slips off before the other then the silver needle bends over. Then if you try to straighten it, it breaks off. I found out the hard way. That was the second one I had done, the first one came right off without much pulling.
Cheers,
Larry
Cheers,
Larry
