strut question
i'm in the process of rebuilding my rt front control arm, the ball joint fell apart
after only 2-3000 miles. this was a rebuild from partwerks....
i'm using a rennbay kit as soon as it arrives...... now to my question,
i noticed the bushing on top of the strut assembly is starting to crack.
i am planning on this winter to remove the struts and rebuild with koni inserts,
is the upper bushing available anywhere also?
thanks in advance.. this is on my 89 s2
The late strut mounts are very expensive! You would be better off buying camber plates or the solid aluminum strut mount that KLA makes. www.paragon-products.com sells all types.
