Oil cooler help
Oil cooler help
I removed the oil cooler yesterday unfortuantly while I was trying to remove it the inner radiator fell into a container below the car I was using to catch the coolant. Now I have milkshake in the oil radiater any recomendations on how to clean it up.
Originally Posted by Dawson's 924S
Kerosene works as well. A lot of degreasers are simply that anyway. With a degreaser, you can just rinse with water and air dry.
I spent the entire weekend working on this "simple fix", what a pain in the A$$. Late last night to make matters worse I snapped the last bolt while trying to torque them down. After serveral hours I was able to get it out. I keep beating my head against the wall telling myself that doing this myself will be cheaper than taking it to a shop. However after buying a new jack, torque and socket wrenches and waisting the weekend I'm begining to think it would be cheaper to have taken it to a mechanic.
If you have a Tuffy's in the area they have a steam cleaner. One nearby has one and the tech allows me to use it. Did my intake manifold and came out nice. If no Tuffy's then perhaps a national chain shop has one or shops in general, check it out. Dawn dish detergent is known to be used also.
Dal
Dal
