Little K26-8 and K27-6 comparo...
Well,
Greg East and I traded cars for a little bit today. They're pretty comparably modded, except I have a 3" turbo back as compared to his stock exhaust with Bursch test pipe, I have an ebc vs his mbc and I have a K26-8 vs his K27-6.
Power delivery between the two cars feels very different, mine is more immediate with a stronger "hit", his feels more linear and doesn't seem to run out of breath way up top.
Interestingly enough, the cars were basically even on the road tho. Really splitting hairs, I imagine they'd dyno pretty close to one another as well.
So I geuss the moral of the story is that it's not worth replacing a K26-8 with a K27-6 unless the K26-8 has blown up...
We both have Vitesse MAF's. My K26-8 is at full boost at 3000 rpm. If you're not getting full boost till 3800, there's something wrong. Are you using an electronic boost controller?
Originally Posted by 87944turbo
Are both of you using some sort of MAF setup? Also, when do you feel your 26/8 kick in? Mine seems to come in ~3750-4000 RPM.
Woah, even my friend's K27-6 car with stock air sensing and exhaust makes full boost ~3100 RPM. I'd check out your vacuum situation...
The ebc does make a big difference, it's worth the money.
Not sure what my settings are, boost setting is around 35 I think, and I'm running gain and set gain around 15 I believe...
Originally Posted by Tabor
How does that work? If the wastegate is closed, it is closed. It doesn't matter why it is closed, it will still hit max boost at the same time.
EBCs use solenoids or stepper motors which wont bleed air and crack the wastegate open a bit like MBCs.
Felt about the same as mine, hard to say, his boost gauge is below the radio, so it's alot harder to see. His car is also ALOT more quiet than mine, so it's harder to gauge in general what's happening.
