rear reflector
Here are what the the 4 holes would look like in the back after removing the rear reflector panel:
http://www.globewerks.net/personal_i...1/DSCF0183.JPG
It is not a pretty sight.
Originally Posted by orbix
Be sure to post pics of that setup once you're done! I'm curious to see how it turns out- I like the idea, but it'll be great to see what it actually looks like.
I'm fairly certain it was an aftermarket add-on. Most people have bought them already installed by a previous owner and are now wanting to remove them.
_____________
-Scott
85.5 944
96 Mazda Miata
_____________
-Scott
85.5 944
96 Mazda Miata
Originally Posted by iamgod
question...was this peice not on some years or has pretty much everone removed them?
1 Post
I want one to take some parts off of.
I want to put one more "grid" of lights one the rear so the red goes all the way to the lisence plate. That way there is not even any body color in the middle section. just lights then license plateand then lights.
Good or bad?
I also like the blacked out pannel on the white car with the Turbo RS wing.
Good or bad?
Chainsaw
![](https://rennlist.com/forums/images/ranks/veteran_navy.png)
Here is a picture of my reflector. I have ordered some flat black vinyl to cover it. It may last or it may not last. At least it can be peeled off to undo what I have done.
I'm wanting to cover it to make the rear of the car as invisible and nondescript as possible.
NC
NC
Why don't you just remove the thing instead of covering it?
Why do you want your 944 to look nondescript? That's what sets it apart from rx-7s, ford probes, mr2s, and any other common crap with flip up head lights.
My mom's 944 has the reflector. It also has a car phone antenna, and ski racks. This pic is from after I crashed it into a parked Land Rover. I miss that color.
