968 quad throttle body conversion
Old 08-04-2006, 10:36 PM
jgporsche
jgporsche's Avatar
Originally Posted by greenshoes3
so can i use it or not? lol
you "should" be able to.
Old 08-04-2006, 10:49 PM
josephsc
josephsc's Avatar
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
Originally Posted by Hacker-Pschorr
Do these supercharger setups keep the A/C?
No. And that's the only thing that's keeping me from dropping more money into my 944 with the 968 motor....
Old 08-04-2006, 10:50 PM
greenshoes3
greenshoes3's Avatar
do they give any estimate as to how much this beast might cost?
Old 08-04-2006, 10:52 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,204 Likes on 1,243 Posts
Oh well, back to square one - to design my own.
Old 08-07-2006, 11:04 AM
SpeedBump
Happily Amused
SpeedBump's Avatar
For more info on the superchargers you can contact Colin at ninemeister.com
Old 08-07-2006, 11:17 AM
Campeck
Campeck Rulez
Campeck's Avatar
what kind of engine management would you run on that ITB setup. and what kind of load sensing? MAP would fluctuate too much...
alpha n? thats not even that accurate.
Old 08-07-2006, 10:41 PM
inactiveuser92616
inactiveuser92616's Avatar
Campeck, I have seen some racecars that decide the load based solely off of: Throttle position, temp, and ambient pressure. Its really an awful way to do it, but it can be done. The mazda engines in Formula SCCA cars do it this way.
Old 08-07-2006, 11:54 PM
944CS
944CS's Avatar
you can connect a vacuum line to all 4 intake runners and have them going to one line, then connect that to a map sensor. If you tune the engine accordingly it will run ok
this design is sure to suck in a lot of hot air....i hope hes not disappointed with his power numbers
Old 08-08-2006, 01:43 AM
theedge
theedge's Avatar
Or run the four lines to a resevoir type deal which smooths out the fluctuations and provides a good vacuum for the brake booster.
Or Alpha-N which doesnt use a MAP or AFM or MAF at all. But yuck to that.
Quick Reply: 968 quad throttle body conversion
