NEED URGENT HELP! transmission/clutch problems
#31
guess its into the shop for my car
id do it myself but reaaaaaaalllllyyy dont want to do it on jack stands and the school is closed for the summer so i cant use their hoist!
Anyone know what a decent clutch kit will cost
and what approx they will charge me for labour...
also if anyone is from vancouver , can anygood shops around i should look into?
#33
$2000 USD?! that seems a bit pricy. i heard its about a 10 hour job max...
$80/h x 10 + price of clutch kit = ?
did u do it in your driveway on stands? if so how hard was it to do?
#34
For a 944 NA, the book rate is 16 hours, for Turbo with a two piece crossover it's 20 hours, and for the Turbo with a one piece it's 24 hours. I did mine in my garage with jack stands, I can't say it was a pleasurable job, but it definitely saved me money. If I were to do it again I would probably buy taller jack stands. It's really not that hard, it entails removing the exhaust, unbolting the axles, dropping the transmission, pulling the torque tube back slightly, and then digging into the bellhousing. It just takes a lot of time on your back. Fortunately I have a 968 now and the German engineers had a engineering epiphany and added a access panel to the bellhousing so a clutch job could be done with an hour.
Josh
Josh
#35
Set to Full-Auto
I am (slowly) building a track car out of an 83 944 - I am planning on adding several access holes in the tub - one of them right at the top of the bell housing for sure!
#36
The clutch job for a S2 is different than a 2.5 n/a since the clutch kit is more expensive. I would say $1500 is around where it should be at. If you don't have the tools or prior wrenching skills, let someone else do it.
#37
started on te clucth last night around9:30, by 2:00 we had everything out, today i will remove the clutch, order the new one and hope fully be able to install it tongiht or tomorrow mornign! Was quite the easy job! i can't belive i even thought about paying a shop to do this!
#38
