blower switch - Brilliant
Mine(86 951) decided to start only working on 4.
How much for part? How hard to replace?
Thanks for the advice. Cleaned the contacts and it worked.
Cleaning the contacts. Brilliant!
It is under the plastic cover inside the engine compartment. The assembly is held in place by two screws and has on connector attached to it. Lots of good pictures in the post below. Remember to clean up the two thermal limit contacts, they are very offen the problem. If you want a description of how it works, I will be glad to write up a quick description.
https://rennlist.com/forums/924-931-944-951-968-forum/52051-blower-motor-high-speed-only.html
beab951 ...
I'm have the same problem and read about your ... "mixture of equal amounts of saturated salt water and vinegar heated to around 150F".
How do you make or where would I find "saturated salt water"?
Could I make do with just the vinegar and would I still need to heat it?
Would some of that electrical contact cleaner from Radio Shack work?
Alex Portanova
1989 944 N/A
1999 Chrysler 300M
1992 Harley FXSTC
Alex Portanova
1989 944 N/A
1999 Chrysler 300M
1992 Harley FXSTC
Hmm ... I was out today and twisted the **** a back and forth a few times and now it's blowing at all speeds. In and out of the car three times and it worked every time. I guess it wasn't the same problem.
Good luck with yours.
Alex Portanova
1989 944 N/A
1999 Chrysler 300M
1992 Harley FXSTC
Alex Portanova
1989 944 N/A
1999 Chrysler 300M
1992 Harley FXSTC
Originally Posted by Alxx Nova
beab951 ...
Alex Portanova
1989 944 N/A
1999 Chrysler 300M
1992 Harley FXSTC
Alex Portanova
1989 944 N/A
1999 Chrysler 300M
1992 Harley FXSTC
The copper oxide is heavy so contact cleaners will do little to cut it. It developed over 20 years so it needs a good cleaning.
Alex Portanova
1989 944 N/A
1999 Chrysler 300M
1992 Harley FXSTC
Alex Portanova
1989 944 N/A
1999 Chrysler 300M
1992 Harley FXSTC
