87turbo clutch in 85.5 na
A centreforce clutch is available on PCA classified. It came out of a 87 turbo. Any comments on it fitting my 85.5
Hates Family Guy
Quick answer: No
More complicated answer: Yes, if you use a turbo bell housing, flywheel, pressure plate, I probably left some parts out. Then there's the issue the turbo flywheel has more teeth and the speed sensor might be thrown off. There was just a thread about this a couple of days ago, you can probably search and find it.
Thanks Kurt, I did dig a bit deeper and the consenus seems to be' once you are in there' do it right and use new parts and you are right the turbo is quite a bit different.
Do a lot of searching before you buy your clutch kit. Some places are charging $500+ for the kit when you can get it on ebay for like $425 shipped.
