How is this Panel Removed?
I have a small dent in the middle of this front panel (not visible in below pic) so I am going to have a PDR expert bump it out for me. However there is no way for him to get his tools to the dent so I will have to remove the panel for him to access it.
Question is then, how do I do it? Is there a procedure posted anywhere that someone could point me to?
Thanks for any help!
Click below thumbnail for larger version
I believe there a 5 or 6 black phillps head screws along the top of that panel that you can see from under the hood. Then there are 2 nuts (1 on each side) in the very corners underneth the rubber that the headlights rest on. And then there are 2 screws towards the inside of the panel located on the outsides of where the intercooler is. Then you can loosen the 4 nuts (2 on each side) that hold the panel tabs down to the frame and side the panel off towards the front of the car.
Originally Posted by Rock
I followed the Clark's garage instructions, and pulled and yelled and pulled and cursed before I found those screws.
The Clark's garage procedure doesn't mention the two screws holding the header to the structure in front of the radiator. Look inside the raised headlights, you'll see a phillips screw on each side that holds the panel to that structure.
