Bolt sizes/threads for helicoils/timeserts?
I need to re-thread some bolt holes on my 951. I used a torque wrench when I re-assembled my 951, but I learned the hard way that it is out of calibration.
So, I need to know the specs on the some bolts/holes so that I can order the correct inserts to repair the threads.
For the oil pan, I understand that they are M6x1.00x10mm, is that roughly correct? I should probably order 10 or 15 of these, since a few of them stripped, and some were questionable.
For the steering rack mounting bolts, what size are they?
M8x1.25x20mm?..... I can't tell without removing my rack which isn't possible with the car in it's current position/location.
Of course when I refer to length, I mean thread depth in the hole, not bolt length.
I have a couple local shops where I can buy the insert kits, but if somebody knows a place online that is really cheap I would rather save a few bucks.
BTW: sorry for post-whoring
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
Originally Posted by Zero10
For the steering rack mounting bolts, what size are they? M8x1.25x20mm?
I'd look up the other ones in PET.
30lb-ft, eh?...
I did mine to 25 and one of them just kept turning....
Perhaps even my new torque wrench is buggered.
I'll timesert them, and I don't think they will ever back out again. I wonder how deep the threads are though?....
haha, yikes. I read 27lb/ft somewhere.... apparently I had the wrong specs.
I rounded it to 25lb-ft and went with that.
Come to think of it, I might have a spare crossmember that I can use instead. The threads on it would be just fine, but I'll need new bolts.
