Old vs. New belly pan
Will a belly pan from a later 944 fit an early one? I believe the early pans were metal and the later ones were plastic.
____________________________________
1986 944 NA - Guards Red - 90k miles
1983 944 NA - Platinum metallic - beginning a new life
1985.1 944 NA - Guards Red - donor car
1984 911 Carrera Coupe - Guards Red (gone, but not forgotten)
"If you're not living on the edge, you're not living"
Having seen both pans, but not side to side.. i cant think of a reason why it would not work. It bolts to the lower radiator support (3x) and to the rear half the crossmember, i think 5 or 6 bolts. The metal pan has two extra bolts on each side that goto the frame rail.
The plastic one is much more convenient. Those two extra bolt locations on the metal one are always the hardest to fasten, and the metal pan is just heavy when you're lying on your back. Try it out!
