removing just the shift linkage? bending it? *update now with pics*
Old 07-08-2006, 04:07 PM
emwporsche
emwporsche's Avatar
Default removing just the shift linkage? bending it? *update now with pics*
is this possible?
it's rubbing somewhere and I need to bend it to fit better.
or I was thinking maybe i could heat it up put and something inbetween where's its rubbing, and then pull up on the linkage to put a slight bend in it, yeah, no?
also the 13mm bolt that bolts the linkage to the transmission broke off.
any recommendations on getting it out?
do I have to drop the tranny?
anything else I should replace if I do have to drop the tranny?
(tranny mount etc)
thanks!
Old 07-08-2006, 05:02 PM
mein51
mein51's Avatar
I've only had my linkage out when I was having my motor out also. What is it rubbing on? I would think fixing what its rubbing on rather than bending the linkage would be a better idea.
Old 07-08-2006, 05:31 PM
Geo
Geo's Avatar
My thoughts exactly. The car was designed w/o rubbing linkage, so unless it was previously damaged and bent, I wouldn't go bending it.
Jake, when are you moving to Houston, and where in Houston?
Old 07-08-2006, 05:42 PM
emwporsche
emwporsche's Avatar
it's rubbing on the body, which I could dent if I had to...
take a look at my sig to see why it doesn't all fit like a normal stock car would.
Old 07-08-2006, 06:53 PM
JimV8
JimV8's Avatar
You have either seriously fuked something or the car has crashed in the past. You need to drop the transaxle to set this stuff right. That might sound big but its not. i just dropped an replacement into my 85.5 and it wasn't bad, but you want to either build a bracket on a floor jack or find a tranny jack as the sucker gets pretty heavy and its awkward working up there. Good luck, I'd help out but Seattle is a bit far.
Old 07-09-2006, 04:40 AM
emwporsche
emwporsche's Avatar
bump
Old 07-14-2006, 12:26 AM
emwporsche
emwporsche's Avatar
ok so I broke this bolt (in red):
it's B in this pic?
is this the one with safety wire?
can I get it out without removing the tranny?
if so, how?
Old 07-14-2006, 12:33 AM
MM951
MM951's Avatar
irrc that is the splined shaft coming out of the transmission with a pin you use to tighten it? If you broke that I don't know how you'd replace it without pulling out the transmission (or the casing) but if you broke the actual linkage i've got a spare I can send you
Old 07-14-2006, 02:19 AM
emwporsche
emwporsche's Avatar
I just broke the bolt. I'm having a hard time getting a hold of one too.
Old 07-14-2006, 03:04 AM
josephsc
josephsc's Avatar
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
The red circle is all over the place. If it's bolt B, isn't it just a standard M8 bolt? Can you get a vice-grip on what's left? Otherwise, I'd just drop the tranny to get better work space (not much room up there). If it's the pin that goes into the transmission, ugh... good luck....
Old 07-14-2006, 04:00 AM
KuHL 951
Hey Man
KuHL 951's Avatar
Joeseph is right. If that bolt has sheared it's easier to drop the TA than try to work on it in place. Dropping the TA isn't that hard and at least you will know the repair was done right.
Old 07-14-2006, 10:00 AM
emwporsche
emwporsche's Avatar
does anyone know what part number that bolt is?
Old 07-14-2006, 11:04 AM
aribop
aribop's Avatar
bolt B has a conical end that slips into a recess in the shaft for proper alingment. Get a replacement bolt at the dealer. When I needed one, they had a few in stock. They are used on other models also.
Old 07-18-2006, 03:39 AM
josephsc
josephsc's Avatar
I was just going through my spare parts bin, and I think I just found one of those bolts -- conical end, 13mm head, a hole for a safety wire through the head. If you need it, PM me with your address.
Old 07-20-2006, 12:35 AM
emwporsche
emwporsche's Avatar
ok so I got the bolt,
and I put it in with red locktite too
however, it did'nt go all the way in. 1/8" gap between bolt head and what it's screwing into
IS THIS RIGHT?????
Quick Reply: removing just the shift linkage? bending it? *update now with pics*
