how do you remove the rear seatbelts???? (stupid question)
how do you remove the rear seatbelts???? (many of you are thinking: "with a wrench you idiot ") I have tried everything to get the bolt to budge and it wont.Is there a special way to do this or am I just dumb?
thanks
Seb
thanks
Seb
i already had the plastic caps off, but they still wont budge
i also had the correct wrench too.
Im talking about the belt that is mounted to the pillar, not the one mounted to the seat.
sry, kinda new on the whole "tool terms" but whats a breaker bar?
i will go to homedepot and pick up a 1/2" drive socket in 17mm as soon as yellowline responds to this.
i have uninstalled the female ends on both seats, and the bottom parts of the male system, I just cant get enough leverage, I'll go 2 home depot today or tomorrow and get 1, Ill post pix/ response 2morrow.
Under the Radar
Yep. With a longer bar, you produce greater amounts of torque. A 10 inch wrench doesn't compare to an 18"+ bar. Put the seat forward as well, so that you can push on it using your weight. Let gravity do the work, just be careful not to slip and round out the bolt head.
Mine came out with little effort. AS Jon pointed out in another thread a 7/16" -20 thread bolt also wrks if you loose your hardware.
BTW Jon I have those grade 8 7/16-20 2" and wshers if you would like for your roll bar. Pm me with address, I will send them gratis for your help.
another trick I do frequently is to slide my jack handle (~5' long) over the end of the breaker bar, giving me essentially a 5' long wrench. I've yet to find a bolt that won't move under that (although I have broken a few sockets).
