Running car without coolant for 1 minute....
#31
I am rebuilding my Renault Twingo 95 and I'm waiting for a new radiator to arrive. In the meantime I was running the engine to move the car to a different location in the yard and to check how it runs. I have a digital temp gauge connected to the body of the water pump. I don't understand why you all say to run it for less than a minute if the operating temperature takes maybe 15 minutes to be reached. Why not just follow the gauge?
Now I attached the serpentine belt to the water pump so I am a little concerned running the pump without coolant in it. I also don't have coolant in the cylinder block.
#33
I lost a cooling hose at the big track at Willow Springs and tried to limp the car back for a mile (less than 1 minute without coolant) at full throttle as other cars were going over 100mph. By the time I got back to the pit, I caused enough engine damage to have warped the block, cracked the cylinder head, collapsed the piston rings (lost compression in all cylinders), and blew the head gasket.
Running it for a minute or 2 from dead cold is probably ok. That's about all I would run it for without coolant.
#34
#35
That’s right. My truck overheated in -30F weather and registered cold on the gauge. No coolant circulating means hot by the engine and cold by the radiator.
This is precisely why a failed water pump is so dangerous on our 996s.
