Can you tell me what this is? Image Fixed
Nope problem remains, I've tightened, proded and banged evrything under there and I still have my "tunk"
I even took my spare tire, and everything in my trunk out, to be sure.
It seems to happen on the downward motion after a bump on the road. I mean, I hit a bump, the shock starts to compress and then it decompresses and then I get the tunk.
I'm out of ideas.
I'm out of ideas.
I have the same clunk-thunk sound as you describe however mine is definitely from the front end. Like you I have checked everything I know how to check and now I can only put it down to my front left damper which is very soft and seems like it's on the way out, but the sound is more akin to something being loose, and like you said, you notice it on the rebound over every little hump or bump.
The fuel pump is surrounded by a BIG THICK rubber tube and fastened using a clamp to the car, the filter is also fastened to the car using a big clamp, I doubt that they'd loosen up by themselves, unless someone recently changed them and forgot to tighten the clamp.
Is is a metallic type clunk? One problem I had with the S2 is that the exhaust would sometimes bump against the roll bar. You couldn't get it to do it by shaking the exhaust when the car wasn't running, but it would tap the sway bar once in a while when out on the road. A little heat and bending at a local exhaust shop cured that problem. It just needed a tiny bit more space to clear.
edit: Nevermind, you said you checked the exhaust. You did make sure that everything is securely bolted down in the hatch area? The jack, the spare, anything in the side cubbies?
Dal.
Dal.
Ah some progress on this, I tried to pull the hand brake a little to see if the clunk could be related to the hand brake pads and WOW, it stopped!!!!
If I pull the handle for about 2 clicks, I checked and the wheels still move freely but the problem goes away. So I must have a loose brake pad in there. Any ideas!
Thanks all
Thanks all
Take the rear rotors off and see what the problem is. The parking brake is just a simple drum brake inside the rear rotors. Of course you could just live with it until you replace the rotors, fix it then.
If it ain't broke, fix it until it is!
Or, what's more likely is that the parking brake cable is hanging funny/not secured properly and it's banging against the bodywork when you go over bumps.
Dal.
Dal.
Problem Solved
That anoying noise I was getting on every bumps on the road was a loose hand brake pad on the DS rear wheel. One of the small twist springs had come loose. I just put it back and problem gone
Thanks to everyone and special thanks to Derek, Michel, and Marc
Horn maybe but the signal return no. It seems that the momo wheel I have and the wheel hub that was used does not support it.
I also fixed the Alarm System yesterday, Michel gave me the G18 and G19 relays I needed and it works perfectly. First time I tested the alarm it started and I couldn't find how to stop it, I eventually took a rag and stuck it on the horn until it stops Neighboors and the whole familly came out wondereing what was going on. It's very loud
How's you car, still running good I hope after your little mishap
