Replacing catalytic converter
Old 06-15-2006, 07:07 PM
aeronautica86
aeronautica86's Avatar
Originally Posted by nkgosselin
I just had this done today. My 86 failed emissions and was actually reading higher levels after the cat then before it. Yikes.
So I had a catco high flow welded in. Total cost, $375. Seemed about the right price.
did you fail again?
Old 06-15-2006, 10:31 PM
black944 turbo
black944 turbo's Avatar
Also look on e-bay. I saw that someone was making an aftermarket pipe with a cat and everything.
Old 06-15-2006, 10:46 PM
SD Porsche Fan
Cast Iron Man
SD Porsche Fan's Avatar
I replaced mine with this ultra slim model!
Old 06-15-2006, 11:10 PM
aeronautica86
I plan on doing that when I go back to Waco where there is no emissions testing; for now I just need to get my car to pass inspection so I can get the damn thing registered (bought it out of state...)
Old 06-16-2006, 09:51 AM
black944 turbo
Are you sure that it is the cat that is causing it to fail. Mine failed because my AFM was not adjusted properly. Took it to the shop and then bam passed with flying colors. Check that first. Because I know my car with no cat will pass fine.
Old 06-16-2006, 10:00 AM
CBM
CBM's Avatar
There are a couple of used OEM systems on Ebay right now....
Old 06-16-2006, 01:16 PM
Laust Pedersen
Laust Pedersen's Avatar
Originally Posted by aeronautica86
Laust, those are similar to the cats I've been looking at online - though I was planning on a round magnaflow rather than oval; do the oval cats from magnaflow and the like fit better under the car?
PS any of those vacuum manifolds left for an '86 turbo?
Yes, with some cutting and welding the oval Magnaflow ones do fit the original exhaust system. Just angle it so one seam clears the wastegate pipe and the other clears the body.
I still have some VM’s left, just PM me for the details.
Laust
Old 06-16-2006, 03:09 PM
arbeitm
arbeitm's Avatar
I have an NA, but I used the MagnaFlow Carsound cat Model No. 53006. (It's 2.5" in/out). I upgraded my 2 1/4" pipe to 2 1/2". It's a lot smaller than stock and fits fine on the NA. I bought it from Summit Racing for around $ 80 and had a local shop cut the old one out and weld it in.
Old 06-16-2006, 08:51 PM
PORobinSCHE
PORobinSCHE's Avatar
here's my plan for the cat. i found a shop who will remove it. in its place will be a 'cherry bomb' type muffler. then at the back will be a magnaflow resonator.
all this will be done in 3 inch dia pipe.
best part $210 total cost! and they didn't give me any grief about removing the cat.
Robin
Quick Reply: Replacing catalytic converter
