Power Steering Problems (noise when turning)
Mexican Ambassador
ok- so now it's stopped the "stop-go-stop-go-stop-go" thing since i've capped it off with fluid.
but i STILL get the vibration/resistance when turning right. this doesnt happen as much/at all at lower speeds. if i'm running like......a 90 degree turn at......40-45 mph, then it isnt as evident. but on a big, high speed sweeper, i get resistance. it almost feels like there's no power steering when i go that way.
actually- that's almost exactly how it feels. as if i just lose power steering when i make a higher speed (sometimes as low as 60 mph) right hand sweeping turn.
i almost just want to take the belt off and run it without power steering for this weekend's fun run.
if i dont figure it out by then, that's probably what's going to end up happening.....
anyone have any ideas?
Hey Man
Mexican Ambassador
that's the thing, is that it's perfectly normal at low speeds.
when i'm parking, or doing anything like that, it's 100% normal.
then at higher speeds it gets very heavy when turning right.
i'll check under there again tonight, to make sure the tensioner is still intact.
i searched some previous threads and one said that the u-joints on the steering coupler could have siezed and made the steering stiff, but i havent found anything that makes the steering stiff only on one side, and only at speed.
i x-posted on the clarks garage forums, and someone also said the same thing about the u-joints on the steering coupler, but he didnt specify if it was only when turning one way.
how hard is it to replace/repair those u-joints. or is it a replace the whole steering coupler kinda thing?
Mexican Ambassador
Originally Posted by Andial951
Are you sure this whole thing isnt been made up as an excuse for your slow driving on the run this Saturday?
you're just mad cuz your car broke on the taco run.
if i would have gone any faster on that thing, those 928's would have fallen off the side of a cliff.
do you know how hard it is to pilot 6000 lbs of car around a corner?
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Legend Killer
Mexican Ambassador
dude...my car broke from sheer frustration of going so dam slow........who the hell was leading that run???? True about the 928's though...........
last i heard, you were just making excuses cuz you couldnt reach the pedals.
Legend Killer
Originally Posted by KuHL 951
Break it up boys...there's plenty of time Saturday to prove who is the real King of the Ring. Don't make me waste my 5000th post on you guys
![](http://forums.rennlist.com/upload/luche_libre__1_web.jpg)
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
![nono](https://rennlist.com/forums/graemlins/nono.gif)
Anyway its all in good fun................
5000th post.....wow.........not bad considering your not a post ***** like another I know...........
UAE Rennlist Ambassador
As stupid as this sounds, but do you have fluid in the system? you would be hearing air being pushed around from the rack/pressure line while turning if you had low/no fluid.....
Mexican Ambassador
i just put fluid in yesterday.
overfilled it a tiny bit, as a matter of fact.
i want to see if i can drain it, then refill it with something that has a stop leak, or "rack seal" thing. like the lucas oil kinda thing.
is there a procedure for emptying the oil in there?
do i just disconnect one of the lines and hope it comes out, lol?
