944 turbo head on an N/A
Originally Posted by F2 Iceland
What's differrent with the turbo head versus the N/a...
Can i use the turbo head on a N/a motor!!!
I own a 951 head and a 944 n/a head...
I'm changing the headgasket and i was just wondering if there are couple of horsepower that i would get from putting a turbo head on it!!!!
This motor is only for this summer because my 2.8 turbo motor is on the way
Originally Posted by Kurt R
My guess is you will see a gain of 0.05hp due to a slightly better exhaust flow. Not worth it in my opinion. Sell the turbo head and use the money to build your 2.8.
My 2.8 is already built!!!
It's on it's way from the states
There was an article somewhere that said putting a 951 head on the later (or ROW) n/a engines (with the higher compression pistson) yielded some good performance results. I dont remember where I saw it though.
Following the advice of Jim Pasha, I put a 951 head on a 88 (higher compression) block. I also installed a SuperChips, chip. I also used the stock tube exhaust manifold with a Flow Master muffler. He assured me I would be more than happy with the results. As usual, Jim was on the money!!!!
