HG Club
Loved your blog. Unfortunately, most of the work is between me and the car. Defintely replacing the hoses to the ICV before reassembly.
Resistance is Futile
Hey MBC, clean the air stabilizer really well while you are in there, I regret not doing that... my line replacement helped idle a lot, but I should have cleaned the damned device more.
Originally Posted by MyBlackCar
The Factory Manuals says the head washers can not rotate when torquing. How did you guys pull off this trick?
Got Nothin'
Originally Posted by streckfu's951
I went to Home Depot and bought a 4 ft section of threaded pipe that my 1/2" socket drive would fit inside of. Since then, I bought dedicated breaker bar.
Under the Radar
You're going to love the 2 cheesehead bolts that go through the bleeder pipe, the head, and into the block. Other than that and cleaning the surfaces, it wasn't a boring or difficult job. Manifold bolts and studs came out nicely for me.
Hmm, maybe they were Allen. Front of the block, holding down the right angle piece that attaches to the upper rad hose.
Under the Radar
The head of the bolt isn't the problem, they go right by a cooling passage and tend to freeze into the block. You can't remove the head easily with the broken studs stuck in the block. My car needed helicoils.
It was on my car when we did the belts/seals/pump job. I was on the passenger's side of the car shouting some ludicrous obscenity that included many references to bad mother's and their unlawful carnal knowledge... I thought I was going to either cave in the front quarter panel or blow blood vessels in my eyes -- one or the other if there was another 10 seconds worth...
I prefer to work smarter not harder. Leverage is your friend....
