nitrous
Originally Posted by Porsche-O-Phile
If someone made a wet kit worth about 75 hp or so I'd consider it. I inherently don't trust the dry kits. I suppose I could get custom chips made for "on juice" or "off juice" with different fuel maps, but that's a lot of extra work (and expense) for something that arguably SHOULD be available off-the-shelf.
ya as i've said i've probably used it 10 times and it cost me $1000, so each spray was costing me about $100...lol it was just a fun project to do. and of course about all you can do to get more HP out of the N/A
Porsche-O-Phile, There is many diffrent kits that you can get to run 75 wet on a 924S/944. I run a Zex 75wetshot that I toook off my 944S2 now on my 924S. My 924S with the lower compression of 9.7:1 has had no problems running the shot with 0 Retard and 2 stage colder plugs on 93 octane. With that setup though you have to watch the RPM that you floor it and also be careful not to hit the revlimiter so it really is only useful for straitline.
There are better ways to set it up but the above setup is like $500....
On this kit, do you have to flip a switch? Or is it hooked to an RPM activated switch? I had a kit on my 96 Z28 but once turned on it activated and shut off according to RPM.
Also, did you upgrade the fuel pump or put an auxiliary pump?
I am seriously thinking about swapping to a 968 3.0 soon, so for a little fun I thought Nitrous might be fun on the old engine. Its not worth anything anyway, may as well have fun.
