Coolant Leak
Coolant Leak
My car has developed a coolant leak ,I haven't had the time to take a peek but to be honest i'm afraid to even take a look as i'm really strapped for money these days .The radiator was replaced a little over six monthsago so it can't be it ,what are the chances that it is leaking at the water pump?
Under the Radar
Driver side or passenger?
If it's driver, you may be in luck. There's a $10 (shipped to you) plastic fitting that cracks and breaks. The hard part is dropping the radiator to change it, which still isn't that bad if the fix costs $10.
So what's the going price for a water pump/ t-belts job in the SF,Bay Area?
Cast Iron Man
There is a small elbow hose that comes off the waterpump and connects to the tube the feeds the heater core. The hose is about $3.95 from Paragon products. Might be the cause of your passenger side leak. You could do a pressure test pinpoint it.
Cool! How do you do a pressure test?
Cast Iron Man
