Anyone want to help me do my t-belt?? GTG?
Sounds like April 15th it is. I'll have to run down to Columbus that weekend sometime to pickup my new hood thou.
Before i forget, is this everything i'll need?
http://cgi.ebay.com/ebaymotors/OEM-P...QQcmdZViewItem
Rocket Scientist
If I were you, I would at least do the water pump. Maybe even the b shaft seals. If you're not leaking, you will know when you're in there, leave the seals alone. I don't mess around when I do the belts. You don't want to have to do it all over again when your pump fails after 5k miles do you? Happened to me....
