Dieing Engine problem
For the yesterday when i was driving my 90' S2 i was in 4th gear going about 40 MPH and te whole engine completely turned off and i coasted to the nearest turn i could make. I stoped the car and it started right back up. it did this twice yesterday once it happened the 1st time i was heading home and it happened again. Today i figured y dont i see if it will happen again so i went to go and get donuts in it. as i was drving to te shop the car died again. i pulled over and started right back up. after i started it back up i drove downthe road and was sitting in line with my foot on the brake and holding the clutch in 1st waiting to go and it started idling really rough i look down at the gauges and noticed the tempuratur gage all the way to the top white line. so i pulled into a parking spot and turned it off. put the keys right back in and the temp gauge was back at the normal just a tad above the 1st white dash. does anyone have any ideas as to what could be causing this?
It could be a loose ground somewhere.
Does the engine die as if you were turning off the ignition, or does it sputter? If you give it gas, will it continue to run?
