Cooling Fan Question
I tried the search thingy and my puter locked up. Must be a million and one post on this.
I disconnected my fans from the swithch on the radiator. I then proceeded to jump them.
Should both fans have kicked in? Only the little one on the passenger side came on.
Thanks in advance.
Dale
Thanks in advance.
Dale
Check with the ignition and AC turned on. You should get both fans running high speed then. If not, one of them might have gone South.
The six blade fans should swap right in (I have one of each right now) The only tricky thing about getting the fan shroud out is getting to the three top bolts. Once those are out, the shroud drops right out the bottom.
I turned on the ignition and the fan on the passenger side spun at a much higher rpm. the one on the drivers side did not spin at all.
The PO only has three bolts holding the assembly to the radiator. The genius has one at each bottom corner, and one that is to long right in the middle on the top.
So i guess i need to get a new fan. WOO HOO. well atleast i know why i am having heating issues now.
Dale
Hey Man
Dale
Dale
If you want I have the old 3-blade set but persoanlly I wouldn't bother if you need new fans.
Dale
Dale
the genious was only missing one bolt on the bottom and i'd love to see a pic of the long bolt on the top.
87951
Originally Posted by bearone
excuse me but your 1st post said you unhooked the fans at the switch and now you say when the switch is on.......one runs faster.
87951
87951
so to make this more clear as i may not be as articulate as some.
I disconnected the fans from the radiator switch and then proceeded to jump the two leads with a metal object ( a paperclip to be exact ). By doing this, i created continuity between the 2 leads to simulate the thermal switch activating.
I then turned the ignition to the on position as suggested by jpk. When i did this the fan on the passenger side began to spin at a higher RPM (revolutions per minute) than it did with the ignition in the off position. The fan on the drivers side (the side with the steering wheel) did not activate with the ignition in the on or off position.
Conclusion = The fan on the drivers side is no longer operational and will need to be replaced.
I will get a pic of the fastener that is too long when i pull the fans out.
Dale
