Pontiac Sunfire headlights-?
Sorry my second image was not updated for some reason.
Scroll up if you want to see inside^^^
From the outside it looks alright.
If you don't mind overspray and the fact that the fenders are now blended with the header panel...
Then you pop the hood and![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
That is a honda water bottle behind the passenger light.
And that is foam sprayed in around them to hold the lights in place.
Mexican Ambassador
i'm sure if this was cleaned up a bit (no overspray, cleaner lines, no *FOAM*, no honda equipment, etc), it would be an OK job.
IMHO, the factory headlight assembly is a mess, and this would give you lots of room to work with (as far as when you need to fix simple things on the car...i.e. *distributor cap
i'd do it if i had a competent body guy that would leave it looking a bit better than that thing..
Wax On, Wax Off
Originally Posted by FSAEracer03
I have a picture of that very car... and it's front end looks like a chimp's butt. Granted, I wouldn't mind driving it with the powerband it has.
post it up!
