How long should this job take?
The coolant expansion tank should take no longer than 10 min (only 3 screws hold it to the car) depending on how old the hoses are that are hooked up to it. The water pump should take about 4 hours if you are not doing the Timing belt & rollers.
By turbo waterpump are you talking about the little electric deal that runs after the car is shut off?? That should not take too long ... I would think an hour at the most (after you remove all of the intake stuff that is in the way).
Has your (electric) turbo waterpump stopped working? Back when I had my 951 I was about to buy a new pump. Then somebody told me to loosen the brakcet that it sits in and twist it - I can't remember if it was clockwise or counterclockwise. I did this along with replacing the fuse and it worked perfectly for the rest of the time I owned the car.
I tried to find the faq or message I read this in, but it was back in the Porschephile board days - no luck. Give it a try though.
