NEED 2.7L VALVES! timing belt disaster
Campeck Rulez
hey guys. Me and my dad helped a friend out one day and got a 2.7L motor out of a full days work. problem is the valves are bent! and at over $100 a pop we cant afford them. PLEEEEASE someone help us out. anyone with 4 exhaust valves and maybe 2 intake valves? i cant wait to get this motor in my car!
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
ohh man! the same happened to me the day I got my 89. The price is crazy for the vavles, but the 2.7 motor is worth it. I wish i had some for you but i just replaced the bent vavles and have no good ones as spares.
No, I have seen quite a few with many bent valves, just from the failure of the belt, not always a mistiming problem.
If you do not replace the valve guides, you will use more oil than normal. Not necessary for a cheapo fix, but if you want to do it right, you cant just throw new valves in.
I thought bent valves would look a lot more bent than the picture shows... Maybe I'm just blind. I can't help you with the valves, but if you decide to part it out, I want that head, whatever condition it's in. I hope you can get it fixed though - I hear the 2.7s are a kick.
All the valves dont have to be open at the same time to get bent. It is possible to bend all of the valves if the engine is spinning fast enough when the failure happens.
Originally Posted by rockfan4
The exhaust valves should be the same as a 2.5l, only the intakes are bigger.
Hope that helps.
Hope that helps.
