Ok - who wants to upgrade to an S2?
I have an 89 S2, 245k on chassis, 40k on engine rebuild for sale in southern New Hampshire.
It needs a little work:
Some cosmetic issues on nose and headlight covers, small rust bubble on right front fender. Fog lamp lens has a crack in it. You'll need to re-time the cams on the car too - it starts and runs but needs some tweaking.
It's got s4 brakes up front, Koni's on all 4 corners. Was a track car that was well taken care of - have years of documentation. 10 speaker factory stereo system.
Looking for 4500 for the car.
Email me at jayc@rennlist.com for more info.
Not if they are only a small off after installation. They need to be carefully timed with micrometers and a degree wheel or timing tape for full performance. They can also be slapped in, eyeballed and pronounced correct (which is a common procedure in many shops.) Then it comes down to luck. This generally works if the same cams are going back in _and_ everything was marked at disassembly and put back the same way (and the cambelt put on correctly.)
-Joel.
-Joel.
