excessive fuel consumption ?
I think "16" is really burning petrol.
she runs ok, seems to be mainly when I stop and start engine.
Need to do some more tests but I think she really is sucking juice (even with me driving carefuilly and motorway)
ideas,
she is due for a service, but couple of months back I did an oil change and checked and gapped the spark plugs, sure last year the filter was changed and was ok anyway
thankxs
Ade
ideas,
thankxs
Ade
The air bypass only affects the idle CO. You have to take the cover off and play with the spring tension on the flap for midrange adjustment. IF the AFS has never been opened then there is no reason to remove the cover and play with the spring. However you can relocate the wiper contacts to fresh carbon resistor material. www.frwilk.com
My car is also running extremely rich. The first thing I am going to test is the fuel pressure regulator.
I would have tested the pressure in the rail today, but someone broke the rail retaining bolt closest to the distributor off. So I can’t put any torque on the cap at the end without twisting the whole rail. I’ll have take out the broken bolt and install a new one before going any further.
firt things first (embarresed)
all tyres were about 5 psi low when HOT !
so have done that, checked for fuel leaks & smells etc.
nothing.
so wanna check the MPG this week and see how I go.
I'll holla back
cheers
Ade
nothing.
I'll holla back
cheers
Ade
