my NOx emissions doubled since last time
Originally Posted by Bill Swift
Richening up the mixture a bit, within the HC and CO limits will probably help with your NOX readings. As I stated before, if you are running too lean higher Nox readings can result. Do you recall what the other readings were? Anyway, turn the AFM adjustment screw clockwise to richen the mixture, but try to do this on a gas analyzer to make sure you don't overdo it.
If you turn the AFM screw, it will ONLY adjust your idle mixture. Pop the top off your AFM for the main adjustments but make sure you know what you are doing or else you are going to be in for one heck of an experience.
