Re-Keying Lock Cylinders
Well, evidentally the cars door was damaged in the PO's mechanics lot, who tried to replace it and pass it off as the original. He never got around to the lock cylinder which I ended up doing, but now its extremely difficult to turn the working cylinder in the drivers door (4 hours later). Upon inserting the key into the cylinder, I notice a few of the tumblers stick up just a tiny bit, of course a proper fit for the key, but the handle hates it. Could this be a problem with a bad copy of the key? Are these cylinders hard to get rekeyed? I could easily do it myself I'm sure if I had the tumblers, but I have absolutely no idea where to do any of this.
Its possible to take out the cylinder without removing the door panel but the plastic piece that snaps onto the door handle is difficult to reinstall that way. File the tumbler is the easy cheap way but the locksmith will replace it with the proper ones. Filing in the inside of the tumbler is the right way to do it though filing the outside will work also.
i doubt you can buy them individually, we re-key house locks at ace hardware, and when we order tumblers, you get them in packs of 12... and you need to know what size. we have gauges at work, but i dont know how it would work with double sided keys. much easier to take it to a locksmith, or file it. or remove the ones that stick up too high (thats what i did for my alarm cylinder)
Originally Posted by WhoDak
You can buy a VW tumbler set at places online...but I found it was cheaper to take it to a locksmith and have him rekey it in about 10 minutes.
Originally Posted by Legoland951
Cylinders are different but the tumblers are the same.
Here's what I did, first the key I wanted to keep worked in the ignition and the rear hatch, so I removed the cylinders from both door handles. I took out all the tumblers from both cylinders and started with the drivers side. It takes a minute or so to figure out what kind of tumbler you need but trial and error gets you going. I put one tumbler in, put the key in and tried it in the cylinder. then went to the next and so on. It worked really well. For the passenger side I did the same until I ran out of tumblers that would work, then I began filing down a few to make them work. I think I only needed to file down about three.
It's really not too hard, but I did do this once before on my VW so I wasn't as intimidated.
Oh watch out for the little springs, don't lose them if the fall out.
