Need parts PS Pump adjuster
Made a more thorough inspection under car and wondering if anyone has a adjustment rod and ends for PS Pump. Runs from the pump to a bracket and appears to adjust tension on the belt. Let me know how much.
Any suggestions on installing metal trim around quarter window?
EDIT- (looks like I'll take out the window, love that search but sometimes I
have to browse quite awhile)
Is there typically oil leaks around rear cam seal, oil pan, and oil cooler connections at filter??. If so do you worry about them or just fix them as time allows. Appears it slings quite abit near clutch housing. Anyone ever have the oil affect clutch performance?
Also very small amount of coolant (a couple of drips mixed in with oil drops) any comman leak points to start checking at.
Thanks in advance for any advice.
Did I post in the wrong forum or what??? Do parts request go elsewhere. I figured this would be a pretty common salvage item on the board. Surely someone has one they can part with, for a price of course.
...are there anymore out there up for grabs? Could also use the hardware that attacked it ( or nut/bolt sizes ).
Heybiff
Heybiff
