Safe chemical for dissolving adhesive?
Originally Posted by sharky47
Car is outside, are Nitrile gloves good for tolulene?
IF, your really worried about the chemical aspect of all this stuff, you need to go to an industrial supply company, and/or ...look up all the chemicals that you are going to be using, and what they require as far as "personal protective equiptment". Find out what the chemical makeup is in the product your gonna use, then, look up the MSDS on it ( I believe a lot are online, and all companies producing these chemicals MUST make this available), and take a looky-peeky. I'll warn ya though........its liable to scare the living CRAP outta ya! Typical stuff, however. I deal with more chemical crap at Boeing than you can shake a stick at! Don't worry.....Be Happy!.........Die young!
Only kidding, about the last part! Better safe.......than STUPID!!
Sort of a related question...
My "new" `87 944S has the obligatory oval "D" sticker next to the license plate. Most of it has flaked away so I want to remove the rest (I also hate stickers all together). Any ideas that won't hurt the paint?
Originally Posted by jim 7
Basically you need tolulene to loosen glue. Make sure you avoid skin contact as absortion is 100% and goes to your internals, not so good. And have good ventilation or do it outside.
Please use this stuff in a WELL ventilated area. Tolulene is the stuff in glue that "huffers" inhale. Yep the old airplane glue buzzzzz. Not good for brain cells or the liver. Makes for a very good octane booster though. ;^)
Disclaimer: My car is a track car, so even though I like it to look nice, I'm not overly concerned with minor blemishes. I would recommend testing any product in an inconspicuous area first before using anywhere it might stand out.
WD-40 is like Clark's Garage -try using it first to help with whatever you're doing!
