Twin Pipe Exhaust: True Love?
http://www.essentialstyling.com/944%20external%20.wmv
at
http://www.essentialstyling.com/944_s2_system.htm
I am absolutely HOOKED on the sound of that car, and inquired to purchase the cat omit pipe and twin-pipe exhaust, and ship it here to USA. $1200 USD
Anyone know a way for me to duplicate that sound for cheaper? I'd like to go stainless since my pipes have been cut up and welded far too many times. Currently, theres a busted magnaflow muffler mounted with a partially clogged cat.
at
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
True dual exhausts are only needed or nessasary on V-8's and really high strung 4's and 6's. Lower the backpressure to much and you lose some power. I'd go with a 3 inch single and dual tips if you like the look.
The dual pipes tips probably have little if any effect on the sound. The rest of the system, mainly the muffler, will have much more influence over the sound.
I've always thought it would be cool to do a dual-pipe setup on a turbo though, with the 2nd pipe being an open exhaust off the wastegate.
Originally Posted by R4][N_M4l{3R
Right on, if you only have one header, you only need one exhaust.
Originally Posted by Fishey
Well, We technically have a 4-2-1 and you could just go off of the 4-2 and make it 2 pipes to back of the car. However, I am not sure of the effects of doing this with two smaller pipes instead of one large one. However, it could be done but I don't see the point.
I'll be running two turbos and one exit pipe, 4"!
Running two pipes instead of one large one is sometimes a best option for ground clearance reasons. The S2 and 968 had that setup.
