Camshaft housing bolts (need more space!)
UAE Rennlist Ambassador
Got a leak from the camshaft housing, leaking all over the oil filter, oil cooler and exhaust header 1 and 2.
I was able to remove all the bolts, two of which are a pain (middle ones) since the suspension chassis is in the way.
I used a 1/2" ratchet with a 6" long 6mm allen socket, problem is, the torque wrench is much beffier than the ratchet (both 1/2" and 3/8" torque wrenches).
I almost rounded one of those two annoying bolts for the camshagt housing.
Anyone has any tips for this? there is very little room for a torque wrench in that spot.
TIA
TIA
I haven't actually removed those bolts, but the attached photo shows the clearance using a Stahlwille tool 2049. It's about 4" long. Plenty of room for a torque wrench, though it seems a little tight for the rear-most bolt.
Actually, a shorty allen socket with a 3" extension and or adapter would work fine in there. I don't have all those high class tools like 6" sockets and such, lol.
Addic
i didnt even have an allen socket.. long allen wrench with a pair of channel locks to twist it. got it off (but im def getting a socket to put it back together, a few times i thought the allen wrench was going to shatter)
Thanks everyone
Went to the hardware store, got myself a 6mm 3/8" drive allen socket, allong with a 3" and a 6" extention just incase.
Got more room now, however, when i used allen keys to remove the bolts, one key actually broke and is now stuck in the bolt.
So now, i am off again to get a drill bit that can drill into hard steel![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
Merry Christmas and happy holidays to you, and you're family
No go, it sits flush with the bolt and i can't get a good grip.
I just torqued everything back together, and tomorrow i am off to the machine shop (with the car) and hope he could tack weld a rod and just pull it out (or something).
Note: Drilling is worthless when it comes to hardened steel!
Well, after spending 2-3 hours trying to take it out, it wouldn't budge.
Went to the machine shop, they tack welded a rod in there, and just pulled it out. Took 2 mins in total....charged me AED 30 (around $8) for this.
