Momo wheel horn questions
Ok,
So I did my research and followed the 944s2 website, bought the 928 horn contact thing, searched here, drilled the hole at pin 71 on my multi switch, now I have one more question...
What did you guys use to wire to the pin coming out of hole 71 now? Did you go to the dealer and buy a factory end, or were you able to make something else work?
I went to Radio Shack and bought a female connector that the pin on the 928 contact would fit. I then cut horn contact wire (I don't remember the wire color but there is a yellow plug in the line), crimped on the radio shack connector to this wire, and then mated this to the pin on the back of the 928 contact (after fitting the 928 contact onto the combo switch).
I hope this makes sense.
Yeah, I rummaged through my workbench and found something I was able to make work. Now I just have to wait till my 8 month old takes another nap and I'll put everything back together.
