WTB in SoCal: 1 working used lifter...
Old 12-25-2005, 01:23 AM
shmucklebuckle
shmucklebuckle's Avatar
Originally Posted by nine-44
I've yet to meet a lifter that wouldn't shut up. Most of them after 50 miles at most. Had one in dad's 951 that refused to quiet even after about 150 miles. I put a half bottle of Marvel Mystrey oil in the oil and it was quiet apon operating temp. Been quiet since. Good luck
I've read recently around here about people running some ATF fluid (I think?) in their oil to clean stuff out... Is there any concensus on whether that would be better than running Marvel Mystery Oil before and after (in a lesser proportion) an oil change?
Old 12-25-2005, 04:08 AM
Dilberto
Dilberto's Avatar
tip the rear end up about 8-10inches. For some reason, I was always able to quell the clacking after a few minutes.
Zach
Old 12-25-2005, 04:27 AM
Zero10
Zero10's Avatar
I've never seen a lifter actually fail. In all of the ones I've seen they just get plugged up.
Now, if you were fiddling around with it, that could cause problems, and if you think this is the reason, I'd replace it just to be on the safe side.
Old 12-25-2005, 11:02 AM
Dennis Wilson
Dennis Wilson's Avatar
Trevor,
ATF, like Risolone and Marvel Mystery oil, are low viscosity lubricants that are also high in detergents. Since ATF is not formulated to run in engines, it should only be used for short periods.
Dennis
Quick Reply: WTB in SoCal: 1 working used lifter...
