Cost of re-doing 944 engine
I´m looking at a 1987 944 S that has done 174000 miles (american specs) and is well mantained.
If I buy this car and I have to redo the engine some day (sooner or later) what is the cost of doing it?(labour + parts)
Porsche parts are very expensive here
but labour is cheaper
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
1 Post
I hate to discourage you, but these cars brake a lot. The design is mostly great, but the age shows up eventually. An almost 19 years old car will keep breaking. I don't know about the currency exchange rate, but if you consider the parts to be expensive in Argentina, you might not be able to afford the repairs. As a rule of thumb, you should assume the cost of replacing parts will match the purchase price within 3 years or so.
Well first youll need some german engineers, a dedicated machine shop, a bolt store, testing team, .. ohhh you just want to rebuild it! ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
ask stig. :/ it will cost about 2500-3000 parts and labor here in the US to have a full rebuild done i think... 1500 or so if you do it yourself. Not sure wiht your parts prices
Thanks for your answers - and selling offer
- I think I will pass on this particular car because the mileage is too high.
I suspect the cost of redoing the engine will be close to 5/6000 dollars here and I will still have an old car with many other potencial problems (clutch, gearbox, etc)
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Here is what you need to consider when rebuilding the motor:
-Cylinders will need to be honed in order for piston rings to seat and seal properly.
-Block may need to be bored if cylinders are out of round. (YES ALUSIL CYLINDERS CAN HAVE THIS HAPPEN)
-Oil pump will need to be rebuild if that many miles. (simple)
-Crankshaft will need to be polished and checked. It may need regrinding
-Check all main bearing journals.
-Replace rod bearings and main bearings.
-Replace piston rings.
-Rebuild Cylinder Head and Machining
I'm in the process of rebuilding my own motor. Save yourself the price of labor and do it yourself
Don't sweat the mileage. I am the original owner of a one owner 1987 944s daily driver and it only has 235,000 miles now on the original unrebuilt engine. Still runs great. Just maintain 'em well!
