starting trouble
im having starting problems. when i turn the key the engine doesnt turn over. i checked the ignition swich--its good.
im getting a no load voltage of 12.30V at the battery terminals. im not sure if the battery is bad. shouldnt the engine at least turn over at 12.30V which would rule out a bad battery?
Try checking the ground wires at the starter. I am guessing that the battery is still charged and that all of the guages are working as well as fuel pump is sounding.
Michael
Michael
Sounds like a really weak battery:
http://www.repairfaq.org/ELE/F_Car_Battery.html
Open Circuit | Approximate | Average Cell
Battery Voltage | State-of-charge | Specific Gravity
12.65+ 100% 1.265+
12.45 75% 1.225
12.24 50% 1.190
12.06 25% 1.155
11.89 0% 1.120
[If the temperature of the electrolyte is below 70 degrees F (21.1 degrees C), then add .012 volts (12 millivolts) per degree below 70 degrees F to the reading.]
12.65+ 100% 1.265+
12.45 75% 1.225
12.24 50% 1.190
12.06 25% 1.155
11.89 0% 1.120
