Should I buy this car?
Greetings, all. I've got the old toy car just about sold, so I've been looking hard at semi-local 944s before heading afield. The most promising so far is an '84 with a legit 39,XXX on the clock. Interior is nearly perfect. Exterior had some light damage (mostly broken glass) from an in-the-garage accident (a pile of stuff fell on it) which is in the final stages of being repaired. Pre-purchase inspection is already lined up, and owner says it's in need of a timing belt. Price is not nailed down yet - waiting on the final body shop bill - but looks to be in the $4000 - 4500 range. Car will be used for sunny days and auto-x. I know that the 85.5 and later cars are more desireable, but this one is in such good shape. Thoughts?
Check the option code sticker in the rear hatch, might be something with the car that makes it worth a bit more such as upgraded suspension or even the much sought after limited slip. I dont remember the #'s for those options, but im sure someone will chime in with them.
I think its interesting the owner said it needs a timing belt, that leads me to believe he is 'in the know', meaning he probably took care of the car. And also hes atleast an honest guy. Thats all speculation at best however.
$4000-4500 seems about right for a car in that condition i think. A pristine, concourse type car would probably fetch in the area of $6000. Do you plan on doing whatever work this car needs yourself? If not i would tack on about $500-1000 to have the timing belt and whatnot changed if having it done at a shop. Are you going to be footing the bill for the repair work on the body or is the owner doing that?
Sounds about right to me, based on what I've read around these forums. Of course, I'm far from what you'd call an expert.
Somtimes you just have to jump in with both feet and have at it. Hope you enjoy yourself. I know I am.
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
If the car is actually 139K, that is still not necessarily a bad price range, provided that the car is in great shape and there is documentation to show that the original clutch has been replaced.
The clutch is indeed the biggie. If it hasn't been replaced, it won't last much longer (the rubber donut). Expect around $1500 to replace unless you DIY. Ask about the water pump too. If original, you should upgrade this to the new style with the timing belt guard as soon as possible.
Sounds like a pretty good deal to me. What part of the country do you live in? It surprisingly affects the cost of the car quite a bit. Up in the Northeast, these cars seem to carry a higher price tag than the rest of the country.. though it might just be because theres less up here to pick from. Either way.. sounds pretty solid pending a good ppi
Car has only 3 options, according to PCNA - 288 (headlight washers), 409 (leather sport seats), 456 (sport shocks and stabilizers). Wear on steering wheel, seats, shifter consistant with alleged mileage. Didn't think to check the peddle covers - have to check that next trip. Previous owner's brother allegedly ran a Porsche dealership service department at one point in this car's life. Clutch is fine (for now) according to folks I've talked to who have driven the car. Should be ready to roll in the next week or so. We'll see what a drive (and a PPI) reveal.
