RL Special Sale: Rear Sway Bar Droplinks
Old 11-26-2005, 10:29 PM
  #106
awilson40
awilson40's Avatar
Originally Posted by Serge944
Ugh! You're the first to have this problem (to my knowledge). What did I say about those darn tolerances?
My last 11 orders came with just 2 larger spacers (opposed to 4 smaller ones) and then a shorter bolt for the bar to link, so this problem shouldn't occur anymore.
Thanks for the feedback.
No sweat, thats probably the best approach. I'll probably turn down a couple of longer spacers in stainless and do the same thing.
Nice parts though , thanks again for building them.
Old 11-27-2005, 11:03 PM
  #107
Campeck
Campeck Rulez
Campeck's Avatar
When you install them, you have to have your suspension loaded. Then, you put the droplinks on without forcing them on. This is where the length adjustment comes in.
Wood blocks work...
um.....whoops. i didnt have my suspention loaded. and i just put em on at about half the length they would go out. Is that bad? If it is then ill do it right when i drop the rear eccentric.
Old 11-28-2005, 12:18 AM
  #108
Serge944
Serge944's Avatar
Yeah, simply setting them to equal lengths wont quite do it. These are solid metal links so there is no give and you may have preloaded the bar. Ideally, you want to set them to a length which will make them perpendicular to the sway bar arms when the car is neutral.
Quick Reply: RL Special Sale: Rear Sway Bar Droplinks
